Intake/throttle body help
I have a 06 hd2500 chevy that I just built a 408ls, prc heads, 11.1 ect. I need help with what throttle body, intake, fuel pump/pressure I need. I already have 60lb injectors for it. It should make around 500hp.
The NNBS intake would work. Otherwise you could go aftermarket and spend big dollars but I don't know what you are after for budget/looks etc.
A single Walbro 450lph pump would be plenty, then an aftermarket regulator. Keep the fuel pressure are 58 psi.
2doorfury
Jan 14, 2014 01:12 PM
92GMCsierra
13
May 16, 2007 02:34 PM
Blackdog76
Dec 6, 2005 07:12 AM
