Injector connectors
Can we get a list of what vechicle uses what injector connectors?
The Fbodys use the EV1?
99-06? use ??
So forth....
Can clean it up after we get a good list goin and sticky it.
99-06? use ??
So forth....
Here are good pics of each type connector:
WitchHunter Performance - Fuel injector connector types
Still searching for list by make/motor...
I know my 2000 5.3 was Delphi Multec2.
So are the Marine 8.1 - 44#'ers
I pm'd Rich @ FIC, FICINJECTORS (sponsor on ls1tech), to chime in and provide a list for us in this thread.
99-2007 5.3 6.0 8.1 uses a mini Delphi plug. And a 48mm injector Except for flex fuel trucks which use a uscar plug commonly called ev6
08 up trucks all use the uscar plug and a 48mm injector
04 GTO uses mini timer plug and a 60mm injector
05-06 GTO use uscar 48mm injector
All trailblazer Ss use uscar 48mm injector
05 up corvette all use uscar. Ls2 is 48mm, ls3,7,9 is 38mm..
Lsa caddy is same as ls9, early ls1 cts uses 60mm mini timer plug same as f body
All 2010 camaro to present use uscar
Pontiac g8 uses uscar
Hope that helps
Starting with f body 98-02 uses a ev6 60mm long injector with the mini timer Bosch plug commonly called Ev1
Hope that helps
Hope that helps
This needs placed into a Sticky
Sorry I know this is an old thread but I'm just trying to confirm what injector adapter plug I need. I have a 2006 Sierra and I'm going to a ev6 or uscar plug injector. I see a lot of ev1 to ev6, but none that say mini Delphi plug to ev6??? I thought the nbs truck plugs were multec2? Anyone know what adapter I need?
