Got fhat
Old May 23, 2012 | 04:08 PM
TIM Z's Avatar
11 sec. Truck Mod
Originally Posted by Holty
I"ve been running the racetronix hotwire kit for a couple years on my dual in-tank walbro's, works great. glad you are having good luck also TIm.
Thanks josh, good to see ya around!! Glad to hear the harness is built to last.
Originally Posted by wkdivr
You guys with the older return style systems definitely have a better system to work with! I just bought a slightly used 2010 CTS-V pump to do some fitment/mock up checks. I'd ultimately like to see how something would work with a PWM set-up. I might be able to eventually come up with a reasonably priced set-up, but as is the norm in my case, I'll spend a couple thou on test pumps, and hose, just to see what works/fits.
Cool deal Bill, hope this works out for you, Did you happen to see te thread on the camaro ZL1 pump upgrade? Im wondering if the Camaro, caddy and ZR1 share the same fuel pump?
Old May 23, 2012 | 05:21 PM
wkdivr's Avatar
Cool deal Bill, hope this works out for you, Did you happen to see te thread on the camaro ZL1 pump upgrade? Im wondering if the Camaro, caddy and ZR1 share the same fuel pump?[/QUOTE]
Unfortunately.....they don't.
Old May 23, 2012 | 07:18 PM
03sierraslt's Avatar
Much like your's Tim, my hotwire kit also riched up my fueling quite a bit. I had to go in and pull some fuel almost everywhere. In fact I had it out this eve and leaned it up some more.
Old May 24, 2012 | 07:33 AM
slowec's Avatar
Wonder what the limit of a return style truck with a 340 and a hot wire IS??? Who is going to see?
Old May 24, 2012 | 08:27 AM
wkdivr's Avatar
Exclamation
Supersub made 714 to the wheels on the factory flex fuel system, no meth!
Old Jun 5, 2012 | 08:58 AM
slowec's Avatar
Originally Posted by TIM Z
Finally installed my aeromotive 340lph pump and Racetronix hot wire kit,
Went from 11.8ish to 10.4 tonight @ roughly 12psi ( hard to watch the gauge as you guys know haha). So i think theres some better times /power left on the table, as well as a better flowing exhaust too.
That is all, its def. worth upgradeing from the stock wiring/single walbro 255.
Did you happen to check and see if you are running higher than stock pressures now?
Old Jun 5, 2012 | 02:45 PM
Phantomx55's Avatar
Where did you buy this from?
Old Jun 15, 2012 | 03:50 PM
Denali08's Avatar
Was it direct install?
I was told by aeromotive that 340lph stealth pump will not fit stock tank.
Old Jun 15, 2012 | 03:55 PM
TIM Z's Avatar
11 sec. Truck Mod
They told you wrong.
Its the same size as the walbro, fit right in with the same mods the walbro needs, no biggie man, no worries.
Old Jun 15, 2012 | 03:57 PM
TIM Z's Avatar
11 sec. Truck Mod
I have more psi definitley now, Are you asking this as to why my AFR is fatter now?
