Is a fuel pump upgrade needed?
Old Oct 26, 2013 | 02:52 PM
damianldaigle's Avatar
Originally Posted by gamble686
Just because some one is running 500hp on flex fuel pumps doesn't mean its the right way. The opposite is true about fuel pumps as well. With a 340lph pump the stock injectors will work to a higher horsepower. This is the same argument as with stock casting heads. Just, because it works doesn't mean its right.
For his intended power level, The flex fuel would be ideal. You have to consider the FCPM when installing large pumps, There not capable of supporting high amps. If you could, explain to me why it isn't the right way?
Old Oct 26, 2013 | 05:04 PM
gamble686's Avatar
When the fuel pump is smaller than it needs to be fuel pressure will drop at wot especially when spraying nitrous. Thus leading to higher IDCs which will result in a lean condition.
Old Oct 26, 2013 | 05:17 PM
OP, if you would. Specify what size shot your spraying and what future mods you referenced.
Gamble, yes that's common knowledge. I'm asking why it's not the correct way for the guys running 500+ rwhp with NO issues? The flex pump is a safe reliable upgrade.
Old Oct 26, 2013 | 05:44 PM
gamble686's Avatar
Ever seen the IDC's or fuel pressure readings at wot on those 500+HP builds using a stock flex fuel pump? Also I would like you to give actual individuals who have done it with "no issues", because I can't think of any. I am sure it has happened I just don't know who you are talking about.
"intake, LT headers, ported and polished factory heads, cam, 2800 stall"
I would guess he is about 375+ to the wheels. Add the spray he will be around 500rwhp.
Old Oct 26, 2013 | 09:03 PM
Byrdman11
Goneb4u
Ak2007r6
Just to name a few in one thread, IDC's or even mentioned...
https://www.performancetrucks.net/fo...506082/page15/
Old Oct 29, 2013 | 12:53 PM
brickyenne's Avatar
Banned
It seems that some math is required. You may want to take a look to this mobile app: for iPhone or for Android, it has a lot of sections to calculate injector flow, pump flow even for engines running E85 and boost among other cool stuff.
Hope this helps!
Old Oct 29, 2013 | 07:06 PM
BlueThunder5300's Avatar
Registered User
right now im only spraying 125 but if I were to ever get the internals built I would really turn it up. im looking at the walbro 255 and 340 lph but am having a bit of trouble finding one that says it will fit a 2007 Silverado 5.3. also do you have any experience with injectors that might work well with this?
Old Oct 29, 2013 | 07:07 PM
Registered User
does anyone know the LPH of the stock fuel pump?
Old Oct 29, 2013 | 07:13 PM
TIM Z's Avatar
11 sec. Truck Mod
A flex fuel pump is about 200lph and will run about $90 vs walbro is about 255lph $100 vs 340lph pumps $150. Pick your budget based on how far you want to take it. I disagree about the flex fuel being good to 550-600hp. The only way it is lasting that far is if you get big injectors. The ceiling on any fuel component is based on other parts of the fuel system. As for injectors stock injectors are about 24lbs/hr. I would suggest 36lbs as a good budget injector.
You just can't pop in a larger pump on a return less fuel system , it will mess with idle pressure and possibly throw tune off . This is why return less guys run dual pumps with secondary setup on a Hobbs switch.
The 255 is usually fine but the larger. 340 400 and 450s would prop be trouble From what I understand .
Old Oct 29, 2013 | 08:42 PM
There's no pump available at this time due to the jet pump feature ours require. It's an extra port on the pump that fills the fuel module. Others have only recently installed larger (walboro 450) in tank pumps, it's not known if they'll hold up r not.
