Fuel Pump Choices
Old Oct 27, 2014 | 09:01 AM
ihdude's Avatar
Default Fuel Pump Choices
I have a 2001 Chevy with a 408 that should push around 600 HP at the crank. I need to replace a fuel pump so which one and what size should I go with? Thinking of boost in the future to push it to 750 or more at the crank. Looking for an easy upgrade so an install kit, etc would be nice.
Old Oct 27, 2014 | 10:56 AM
FFDP's Avatar
A walbro 450 would meet your needs.
Old Oct 27, 2014 | 11:00 AM
ihdude's Avatar
Would that be this one:
http://www.summitracing.com/parts/vpn-f90000267
Also, is there any other things I need. Wiring harness, etc?
Old Oct 30, 2014 | 11:42 PM
Ferocity02's Avatar
You will need to upgrade the wiring for the 450. You will also need an aftermarket fuel pressure regulator since the 450 will overpower the stock one and leave you with overly high and uncontrollable fuel pressure.
Old Oct 31, 2014 | 06:39 AM
ihdude's Avatar
Will I need a new regulator for a 322 pump? At what fuel pump level do I need to upgrade the wiring? How much wiring has to be upgraded?
GXPJAY
Feb 13, 2022 08:15 AM
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
