fuel pump for 10psi of boost
Old 07-19-2014, 12:41 PM
Denali08's Avatar
I am using aeromotive 340 intank. Doing very well so far. Check my sig. I am using ractronix pump wiring kit because the pump draws more current and will need stronger wiring.
Old 07-21-2014, 08:10 PM
TX Tahoe Z71's Avatar
I went through 3 stock flex fuel pumps at 10psi before I finally got a Walbro 450. Maybe it was the Kenne Bell boost a pump killing them, or maybe they were just being overworked. Or maybe I just have terrible luck. My $.02
Old 07-21-2014, 08:20 PM
Denali08's Avatar
What rwhp can the Walbro 450 support?
Old 07-23-2014, 12:56 AM
08cheyennesc's Avatar
Old 07-28-2014, 01:44 AM
fctry286's Avatar
Originally Posted by Three6GMC
Your truck a flex fuel? If so stock pump works fine on a 5.3 at that boost level. Just remember in the tune or at least on hp tuners there one page that commands 14afr for some wierd reason giving the idea that your pump is not keeping up. I'm still running my stock flex fuel pump on my 427lsx with a 106 on 10lbs so stock will be plenty for your setup.
I do appoligize for not being on. But yes i do have a flex fuel. My A/F is spot on 12.4 WOT pull on the dyno untill 4800-5000rpm and then it jumps straight up to 14ish. Injector duty cycle is at 80%. I even tried adding more fuel from the MAF scaleing table but it did not help at all.
what did you adjust that table to where it reads 14afr. three6gmc?
Old 07-28-2014, 01:45 AM
fctry286's Avatar
is that walbro actually drop in? no mod to the pump housing?
Old 07-28-2014, 02:03 AM
No its not a direct replacement,apparently there's a couple ways to make it work, there's some info on here if you look around.
Old 07-28-2014, 02:07 PM
fctry286's Avatar
Hmm ok may have to look into that. If that is my problem.
Old 07-28-2014, 10:09 PM
If your truck is flexfuel then you can do just what this guy did #262 https://www.performancetrucks.net/fo...e27/?styleid=1
This is how I did my non flexfuel bucket
wrb002
08-31-2015 12:00 PM
05GMC4.8
08-07-2015 09:55 PM
RS/SS 4.8
08-02-2015 11:03 PM
MS3Z
07-30-2015 06:17 PM
Mossyoakglock
07-17-2015 08:30 AM
Quick Reply: fuel pump for 10psi of boost
