Fuel Pressure is WAY Low! Regulator? Pump?
Old Jan 23, 2014 | 08:36 PM
Ferocity02's Avatar
So in other words E.
Basically, yes. Is there a way to install an intake pump without cutting the bottom of the bucket? This might help fuel stay in the bucket to keep the pump cool. When I installed the 255 I cut the bottom of the bucket to put the filter though.
I might get a Walbro 400, I ha pretty much maxed the 255.
Old Jan 23, 2014 | 09:39 PM
BlackGMC's Avatar
Resident Retard
I know on my 04, i can let the level drop until the light comes on with no issues, then again i did not cut the bucket.
I believe you can swap out your tank for a new returnless style, that uses the bigger bucket....
Old Jan 23, 2014 | 09:58 PM
Ferocity02's Avatar
Swap the entire tank or just the bucket/module?
Old Jan 23, 2014 | 10:05 PM
Atomic's Avatar
I have a gauge for that
Swap the whole tank. The hole in the top is a different size. I have made a couple threads about this with pics.
Old Jan 24, 2014 | 12:54 PM
Ferocity02's Avatar
Took apart the regulator this morning and didn't see any obvious problems.
The fuel pump is still priming, it sounds pretty close to normal, but not quite.
I ordered a Walbro 400, a new bucket module, and a new submersible hose. Also have a hot wire kit that has been sitting around that I'll finally be able to install.
Old Jan 31, 2014 | 06:54 PM
Ferocity02's Avatar
Well, turns out the hose burst. Yes, the $20/ft submersible hose. It burst where it was connected to the module, not the pump. Looks like the worm gear hose clamp may have played a part. The hose was also very mushy. It was installed about 22 months and around 10k miles ago. It's only seen 91 octane, no methanol.
I dropped in a Walbro 400 with a proper plastic corrugated hose and Oetiker clamps this time.
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
