Fuel pressure regulator vacuum/boost question
Old 08-20-2014, 09:53 PM
Resident Retard
BlackGMC's Avatar
Well if you do it without the car running your running off the volts in the battery which mine is at 12.5 (in my case). With the car running my volts are 13.7.
With the truck off and turning on the pump my reads 56psi. With it running and vacuum line removed it is 58psi. Not a big difference but a difference.
Old 08-20-2014, 10:07 PM
oakley6575's Avatar
Yea I've never thought about the voltage change. Thats a good thing to consider. Sorry for getting off topic btw.
So are you going to try a different regulator to see if your reference diaphragm is bad or is it not enough of a difference to worry about?
Old 08-20-2014, 10:11 PM
Resident Retard
BlackGMC's Avatar
I still have my aeromotive a1000 regulator i can easily swap inplace of the fuelab to see if it a regulator issue. Perhaps this weekend i try, i dunno.
Old 08-20-2014, 10:48 PM
LS1TRUCKGUY's Avatar
So should the stock fpr function the same way? 1 to 1?? My fuel pressure reads 60psi at idle. It stays around 55-58 under boost...
Old 08-20-2014, 11:11 PM
oakley6575's Avatar
Return or returnless system?
Old 08-21-2014, 12:53 PM
returnless. i assume it is working properly. didnt see any issues while me and my tuner were logging. im familiear with the return systems, just not so much the returnless. never had to mess with it as of yet.
Old 08-21-2014, 02:36 PM
oakley6575's Avatar
Returnless systems stay at 58psi and the IFR table compensates for vacuum situations
Old 08-22-2014, 02:14 AM
oakley6575's Avatar
Hey, don't know what I was thinking last night. Our boost gauges read vacuum in In. HG and not psi. So when it shows -15 on the boost gauge, that is really only 7 psi of vacuum and fuel pressure should be around 51psi. So is your FPR diaphragm doing its job?
Old 08-22-2014, 07:36 AM
I have a gauge for that
Atomic's Avatar
Bingo. Boost gaugea read boost in psi but vacuum in inches of HG. Yours is working fine.
Old 08-22-2014, 08:17 AM
Resident Retard
BlackGMC's Avatar
Dear lord. I am a retard once again. Thanks for setting me straight. Yep it appears everything is fine.
Quick Reply: Fuel pressure regulator vacuum/boost question
