Fuel pressure hickup's.
Ditched my in tank duel Walbro 255's for an external Aeromotive 1000 marine fuel pump. I also added an Aeromotive 100 micron inline fuel filter with a shut valve prior to the pump, also run an Aeromotive boost referenced FP reg set at 32 psi @ idle. At zero inches of vaccum the FP is @ 43 psi and goes from there.
Problem is, is with the cruise control on @ 55 mph, when the hickup accures, I've seen a loss of between 10-12 psi of fuel pressure which cause's a A/F lean spike/back fire. It only last's for a few seconds then the fuel pressure gets back to normal.
I spent most of my day today checking out fuel line restriction's and such.
Drained the tank, checked the filter and all was well.
What should I look at next?
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
