Fuel pressure gauge with long hose
Does anyone sell a fuel pressure gauge with a long enough hose that I could stick it between the wiper and windshield so I can watch it while driving? Trying to figure out a knock issue under load and want to see if it’s fuel related.
I bought this one specifically for the long hose. I haven't had the need to check it while driving yet stuck on the windshield, but I think it's long enough.
https://www.harborfreight.com/basic-...kit-64939.html
Do you have lean codes? What about fuel trims?
Um. If you had a misfire or knock I'd think you would have a code. Still worthwhile to check fuel pressure during load. What engine/vehicle?
I had a rattle sound on my 99 4.3 that I couldn't figure out. Only did it on the highway under load. Turns out, i had done a compression test and threaded the spark plug into the compression test adapter! Embarrassing! This was months later too! 🤕 I never had codes either. I just figured the older black box ECU was not as precise on detection these things. 🤔🤷
Do you know any HVAC/R guys? I have used an old A/C 0-120 psi manifold gauge and hose to do exactly what you described.
This setup also needs a 1/8 female thread to shrader adapter for the gauge. I think the shrader on the engine and the hose is 1/4 flare. So for the gauge you need a 1/8 fpt x 1/4 male flare adapter
Edit: the hose is 38" from the Schrader adapter to the the brass fitting to release the fuel pressure. Mine is the Maddox brand MH-DC19
This is what i use for fuel pressure and transmission line pressure testing.
10' -4an hose reaches into the cab so you can watch pressure.
https://www.summitracing.com/parts/FRA-360120-BU
https://www.summitracing.com/parts/aer-fbm2723
