Fuel pressure drops from 450 kpa to 300 kpa
Old Jul 3, 2018 | 02:11 PM
11Charlie's Avatar
Registered User
Default Fuel pressure drops from 450 kpa to 300 kpa
My first post. I searched and couldnt find anything on this issue. I already changed the fuel pump, but still has the same problem. When I start the truck my fuel pressure is it about 400 to 450 kPa. Once it warms up a little bit I noticed that it drops to 300 kPa. Mind you it does this regular as if it is set by some device to do so. There is a noticeable difference in my idol when it drops to 300 it's it's rough but then when it jumps back to 450 it's nice and smooth. I have a 220 220 581 581 114+4 sleeper cam. My question is what would cause this and how do I fix it.
Thanks for your help in advance
Johnny
Old Jul 3, 2018 | 05:34 PM
FFDP's Avatar
What kind of truck?
Newer trucks have fuel pump control modules that will drop the fuel pressure when 58psi is not required.
Old Jul 3, 2018 | 06:52 PM
11Charlie's Avatar
Registered User
Well, that makes sense. It just seems like I should have more power. I watch my pressure and on wot I'm not seeing an increase in pressure. Should I be looking at something else? I have the aforementioned cam in a Gen4 5.3 with Pacesetter long tube headers, Flowmasters, polished 243 heads, CAI, and MSD wires. It's a 07 crew cab. I have a G80 w/ 3:73 gear. I know this is a dumb question, but any idea what I should be at 0-60. Im just trying to get a ballpark. I'm new to the whole fast truck side of the house.
thunder550
Oct 1, 2006 06:08 PM
treyZ28
37
May 16, 2004 02:33 AM
