Fuel injector advice for e85 s480
Any advice on fuel injectors. Brand, connection style, low or high impedance, well ****, on the whole fuel system I'm open to advice or options.
The plan is HP tuners, E85, speed density, starting with base at 50psi, 160lb injectors or bigger, dual wally 450's in basket (if thats enough pump), -10 feed split to -8 rails and -8 return, or could I get away using the stock feed line as a return?
