E85 Conversion?
Old Jan 30, 2016 | 09:35 PM
!Hostile!'s Avatar
Default E85 Conversion?
Ok guys as the title says I see people are switching to run E85 instead of running Meth. Im wanting to do the same thing since I'm buying all new fuel components to supplement my current build. I'm looking for tried and true setups from you truck vets out there. What works for you. Complete setups.
Heres the run down on my setup so far..
5.3 AFM delete TSP 220 112 LSA. PRC 2.5's KB racing Turbo kit with a 76 ON3 with 80lbs injectors...
So what's your guys suggestion to completely convert to E85 from pump to engine? I appreciate some insight.
Old Jan 30, 2016 | 09:41 PM
George C....'s Avatar
Formerly ScreamingL
Gonna need larger injectors unless goal is 600
Old Jan 30, 2016 | 09:50 PM
!Hostile!'s Avatar
What do you suggest I get/do George if you were doing a complete E85 setup"
I was also looking at that turbo cam you had for sale as well. But need to nail down fuel setup first.
Old Jan 30, 2016 | 10:29 PM
Formerly ScreamingL
Have to be realistic with intentions of vehicle to give idea
Example my e85 fuel system is -12 feed -10 return 225lb injectors at 43 base belt drive pump
You wont need none of this unless you knew that yiu wanted 1500 rwhp range
Old Jan 31, 2016 | 10:56 AM
GMCtrk's Avatar
I'm making around 950 on stock lines and 165 lb injectors with 2 450 pumps
Old Jan 31, 2016 | 02:43 PM
!Hostile!'s Avatar
So my question is will any 450 pumps do and injectors to run e85 with a tune
Old Jan 31, 2016 | 04:34 PM
chopperloco's Avatar
I'm aiming for +/-750 on a walbro 450 and 95lb injectors through stock fuel lines on mine.
Old Feb 1, 2016 | 11:25 AM
GMCtrk's Avatar
not gonna happen on the single pump
Old Feb 3, 2016 | 08:31 AM
!Hostile!'s Avatar
Do I need to swap FECM and Module to run E85?
Old Feb 9, 2016 | 09:29 AM
turboNNBS's Avatar
Almost finished with my 07-13 on3 kit.very nice kit with good fitment imo.
