Alcohol sensor, who's added one
Old 02-14-2016, 07:51 AM
03sierraslt's Avatar
Originally Posted by Gadgetized
How much power do you want to make. I made 955 on my 130's.
On e85? If so then 130's would be big enough. My current 72's are maxed on gas, I plan to add another 3-4 psi on the new motor. Who made your 130's and did they actually have reliable data with them? The same ID1300's that are in your Sig? Would be nice to find them with EV1 plugs
Old 02-14-2016, 08:00 AM
Gadgetized's Avatar
Yes they are ID1300's. They work great, i just plan on turning the power up a little. I think they would still be fine, but I needed other injectors for the other engine. The data provided is great. They run and idle great. They came with EV1 adapter plugs.
Old 02-14-2016, 08:19 AM
Ya I knew they made adapters but prefer the clean install of none. Can I pick my color? Haha
Old 02-14-2016, 08:26 AM
Gadgetized's Avatar
Ha ha I wish. Im not too fond of purple.
Old 02-14-2016, 03:50 PM
chopperloco's Avatar
13577379 is what I used. I actually got new injectors. I just got 160lb Bosch stainless injetors, and will be putting these injectors in my Chevelle. I will be converting that to flex fuel too, but will be making less power.
will this work on a NNBS?
Thanks
Dom
Old 02-14-2016, 06:42 PM
Gadgetized's Avatar
I'm not sure what the NNBS trucks use to determine the alcohol content. If they use a sensor l don't see why it won't work. Some years they used the O2 sensors to calculate it(I never really looked into it too far to see how it worked).
Old 02-16-2016, 02:03 PM
Ferocity02's Avatar
I installed a flex fuel sensor on my 335i. It uses bluetooth to send the ethanol content and fuel temp to my phone. Super easy install, just needs switched power and ground. Of course that doesn't allow you to utilize the extra tables in the PCM.
Old 02-17-2016, 09:22 PM
MikeGyver's Avatar
Ya I knew they made adapters but prefer the clean install of none. ...
ID injectors in their shortest form (no adapters) have no room for the inlet screens that are part of the hats (adapters).
Old 02-18-2016, 04:15 AM
We were talking about wiring adapters for the pigtail.
Old 02-18-2016, 07:22 PM
MikeGyver's Avatar
You're welcome.
Quick Reply: Alcohol sensor, who's added one
