11 Second Hall Moniter
Quote:
Disconnect the filler neck from the bedside. Unplug the wiring harness. Remove the driver side bolts to the frame. Loosen but don't remove the passengers side bed bolts at the frame. Grab a jackstand & lay it accross the top of the left rear tire. Originally Posted by N/ALS1
Yeah that's the problem I only have my father inlaw to help. So two people total. Lol I hope we can lift the bed. If not I guess I'll be going to the dr for a hernia, good thing my deductible is met. It will be covered 100%. Lol
You and your helper lift the driver's side of the bed up, reach down and prop the jack stand between the frame & bed.
Crawl in there and replace your fuel pump.
Is this method tried before?Originally Posted by AKlowriderZ71
Disconnect the filler neck from the bedside. Unplug the wiring harness. Remove the driver side bolts to the frame. Loosen but don't remove the passengers side bed bolts at the frame. Grab a jackstand & lay it accross the top of the left rear tire. You and your helper lift the driver's side of the bed up, reach down and prop the jack stand between the frame & bed.
Quote:
Yes sir. This is the only way to do them IMHO. When I worked at the dealer, could do 3 a day with this method, plus a couple tune ups. Originally Posted by Denali08
Nice def gonna do it now. I was really worried about taking the bed off and busting a nut picking i up. That one post could be a sticky to help others that are in the same boat.
Quote:
How many Jackstands did you use?Originally Posted by AKlowriderZ71
Just one. Don't remove the bolts on the passenger side, just loosen them so it will tilt.
Charlie Murphy!
Quote:
Awesome advice! Thank you.Originally Posted by AKlowriderZ71
Looks like a c-notch to me. It is a brace/support used for lowering a truck. You cut a upside down U notch in the frame for axle clearance and use that brace to prevent frame cracking.
