2013 Chevy Silverado 5.3 FlexFuel Modification
the last log I have right before starting this install, the ethanol content, according to the virtual setup, was 15.3%
after flashing the new settings in firing it back up, the ethanol content is reading 11.8%... I had filled up with 91 octane (from an empty tank) and driven about a half of tank before this install... I am definitely happy with the upgrade and looking forward to moving forward on my truck, without worrying about the virtual sensor issues.
I have quite a few data logs, but not many where i hadnt made changes in the tune. So anything I say as far as an improvement to fuel economy, simply by adding the sensor, may just be an assumption. It makes me way more comfortable now that i upgraded it. When the virtual reading is off, the fuel trims will be off. So I do believe, there may be an improvement, simply by adding the sensor (because it is a more accurate reading). But I wasnt looking for an improvement, in any area other than a more accurate and reliable way to read the content.
Wow! I’ve been waiting for this info! I gave up on E85 and have been running premium gas since I supercharged my 4.8....Time to install the bigger injectors I’ve had sitting collecting dust in the garage.Very nice write up . Thanks for sharing.
I know it's an old thread. I bought a 2013 GMC Sierra with the 6.2 L9H that has a BTR stage 1 V2 cam installed. I brought the truck home and proceeded to fill the gas tank with flex fuel. it took about 14 gallons to fill it up. the next day the check engine light comes on. so I pull the code and it was P0170 for bank 1 and 2. So I ask the internet a bunch of questions about my new truck and find out about the virtual flex fuel sensor. I'm half done with my install, the easy half. I just need to connect the wires for power, ground and the signal to the PCM, and then adjust the tune
Thanks for this write up.
GONEB4U
83
Jun 1, 2016 11:04 PM
Dirty 30
Nov 8, 2014 11:09 PM
98tdi
Sep 5, 2014 07:21 AM
