2005 rcsb
Old Feb 29, 2016 | 08:41 PM
lotto389x's Avatar
Registered User
Default 2005 rcsb
Needing a new fuel pump. Whats everyone using for in-tank?
Also are the newer 2015 wheels a direct bolt up and with tire combo is everone using?
Old Feb 29, 2016 | 11:52 PM
FFDP's Avatar
What are your needs though?
You want a stock pump or are you modded??
And any of the K2XX wheels will fit, the bolt pattern is the same. Tire size and or brand is depends on how you want use your truck. Do you want stock size tires for 17, 18 or 20's or are you going to lower the truck or lift it?? That can determine the combo you'd want.
Old Mar 1, 2016 | 08:49 AM
lotto389x's Avatar
Registered User
Right now I'm @ 500hp. Would lik ed to get a pump to support 600- 800hp.
It's got a 2/4 drop with caltracs. Looking for 18s.
Old Mar 3, 2016 | 09:05 PM
2plus2's Avatar
From what I understand from reading here, most people go with a walbro 450, and they run a new factory fuel feed line with the inline filter and use the current one as a return.
Old Mar 3, 2016 | 10:38 PM
Atomic's Avatar
I have a gauge for that
I would convert to a return style fuel system with dual pumps if you want 800hp, pretty much just like you described.
misfitdsmer
Mar 17, 2016 06:30 AM
SlvrSierra4.8
Feb 16, 2016 08:45 PM
SlvrSierra4.8
Feb 16, 2016 04:10 PM
Txblue
Feb 8, 2016 09:17 PM
