04 truck converting to return style.. needing advice
Old May 11, 2013 | 10:31 PM
MechE's Avatar
Default 04 truck converting to return style.. needing advice
As the title states, I'm converting to return style. Got a couple questions....
Alright.
I bought a walbro 400 pump, do I need to add a check valve, or does the pump have one internally?
Most importantly, can I use my returnless fuel rails somehow? I already have an aeromotive regulator. I also happen to have return style fuel rails, can I just use those with the external regulator? Or should I just some aftermarket rails and be done with it? Just looking for a clean install, with a good budget in mind of course.
Old May 12, 2013 | 07:48 PM
blue0453's Avatar
Just did the swap with the 400. Ran new -8 feed and used a russel factory quick connect to connect to fuel rail. Used another russel qiick connect to connect to factory feed for my return line. Used aero 13129 reg. Ran a summt brand 10 micron inline fuel filter on feed line. Will need a -8 bulkhead for top of bucket and several different fittings depending on how you run your lines under the hood. Go ahead and do a hotwire kit while your at it.
Old May 12, 2013 | 08:25 PM
Atomic's Avatar
I have a gauge for that
You can use either rails..
With the returnless ones you need to put the regulator before the fuel rail on the feed line.
With the return rails you put it after the fuel rails.
Depending on how much power you are shooting for you will want to do it after the rails at some point.
Old May 12, 2013 | 09:22 PM
MechE's Avatar
so if i were to use the return rails... then would i just leave the regulator in the rails as is, or take it out somehow or what?
Old May 13, 2013 | 08:58 PM
blue0453's Avatar
You said you already had a aftermarket reg. Just run the returnless rails and that. Not sure if the 400 will over power the factory return style regulator.
Old May 13, 2013 | 11:08 PM
MechE's Avatar
i can't help but to be a little skeptical of putting the regulator before the rails, i'd rather do it after and just get it over with, as i'd like to really expand my power goals soon with this setup. i have searched and haven't really found anyone using an external fpr with stock return rails, would i really have to buy aftermarket rails?
Old May 15, 2013 | 04:56 AM
blue0453's Avatar
I'm running 15psi with reg before the rails. Afr holds 10.9 at wot. Not saying this is the ideal way but it works for me.
Old May 15, 2013 | 09:51 PM
MechE's Avatar
hmm would you happen to have a link or part numbers for those fittings to connect to the rails and factory lines?
Old Jun 1, 2013 | 03:50 PM
doc350's Avatar
http://www.summitracing.com/search/d...-style/adapter
on the factory return rail, the feed is 3/8" and the return is 5/16" i believe. someone correct me if im wrong.
blownss27
Nov 21, 2016 03:32 PM
black6spdz
Jul 16, 2015 01:32 AM
Sbrown06
Jul 9, 2015 09:21 AM
