Foreign Performance Discussion Nissan, Toyota, Honda, Mitsubishi, Range Rover
Droped my truck 3/5
Old Feb 3, 2008 | 04:20 PM
  #21
Stoichiometric's Avatar
The more coils you cut off your front springs the stiffer they are going to get. You might cut another coil (or portion of) off and get a set of poly spacers to go under the coil to bring the ride height back to where it was. The other thing you might be able to do is put spacers in between two coils to keep them from moving.
Looks good. I don't mind the big tires, better too big than too small.
Old Feb 3, 2008 | 09:12 PM
  #22
shinermiller's Avatar
start launching high man. do like mastiff does. that little **** thinks he's running a 14 flat stock. i called BS. fix ur junk and get to the track dude
Old Feb 3, 2008 | 10:25 PM
  #23
Snacktime's Avatar
Made in South Korea
Originally Posted by moregrip
sweet, good work!
got any pics of the front bump stop and how much room is left after the drop?
the saws-all ate the bump stops
Old Feb 3, 2008 | 10:42 PM
  #24
moregrip's Avatar
what a rush!
ahhh, very good! glad you took care of those pesky things
Old Feb 4, 2008 | 09:17 AM
  #25
Snacktime's Avatar
Made in South Korea
Now if I could get rid of the driveshaft vibration I would be good to go.
Old Feb 4, 2008 | 06:12 PM
  #26
moregrip's Avatar
what a rush!
did you measure the d/s & pinion angle before you did the drop?
Old Feb 4, 2008 | 07:06 PM
  #27
Snacktime's Avatar
Made in South Korea
well the rear driveshaft actual goes down in the rear now...
Pinion angle is correct but the carrier bearing isn't
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
