i have a question, purist beware!
Well i got to thinking, i love the 1997-2002 f150's but i dont like their engine options. So i was wondering how hard it would be to swap in a 5.3 or 6.0 ls styled engine and transmission. Ive seen ls swaps on mustangs and a couple crown victorias which i think share the same mounting points so could i just use one of those swap mounts? What about transmission/fuel/wiring...or ac and all the other options? If this is possible it could very well be in my future...so any help is apreciated :)
LS swaps are pretty easy, but an easier swap is a Lightning 5.4L... it literally plugs up for the most part... the engine harness is different, you can use yours but an L harness has 2 air temp sensors... change that and put a 325 fuel pump in and its good to go! beware of the 4R70W though, they are good transmissions but the weight of a truck will kill it quick... Make sure its either built to handle the weight or put a 4R100 in if you decide to go with a L motor...
I dont have alot of knowledge on fords. Ive allways owned chevy's with the occasional dodge. The lightning engine would be an easy swap? What all would i have to do to swap it? Building up the 4R70W wouldnt be an option considering id build up the 5.4 and i dont think even a well built 4R70W could stand what my ends goal is so the 4R100 would more than likely be needed. So would i have to change the trans mount for that swap?
Well i did some searching and found out that is is a direct bolt in/plug and play engine it just needs to get tuned. But i still need to know about the 4R100 swap.
Originally Posted by FMD
(Post 5116822)
Or could just swap in the navi DOHC 5.4. 300hp stock I think. Idk how hard the swap would be tho.
