2001 f250 super duty wont start
Old Aug 2, 2011 | 03:53 PM
aids's Avatar
Registered User
Default 2001 f250 super duty wont start
Remove all Advertisements
so i have a 2001 f250 and it refuses to start. i tried a new started solenoid and a new started switch thats right beneath the steering column by the fuse panel, checked to see if any wires are cut or disconnected and everything is fine. it just wont start by key. if i turn the key then nothing happens(wont crank at all) but if i touch a piece of metal across the solenoid then it starts right up and runs fine. cant figure this one out. so now also my hubs rattle like crazy, i heard this is pretty common but wether the front hubs are locked or unlocked, it still rattled. what do i need to replace to fix the 2 issues?
update: just found two 7.5 amp fuses that were blown on the engine compartment fuse panel, also found a 20 amp blown fuse. could this be my problem with starting?
Old Aug 13, 2011 | 07:15 AM
Grant218's Avatar
did you try replacing the blown fuses?
Old Sep 11, 2011 | 11:51 AM
Str8Ugly's Avatar
i gave up trying to figure out why my f250 wouldnt start by key i just rigged up a push button on mine. works like a charm
SLOPONY
20
Oct 18, 2016 06:05 AM
treylittlefield
Jan 24, 2016 07:38 PM
smokeshow
Aug 23, 2015 08:23 PM
rojeho
Aug 8, 2015 07:20 PM
