Yukon fueling issues
Old Aug 25, 2010 | 02:55 AM
xclratn's Avatar
Registered User
Default Yukon fueling issues
My 2004 Yukon with a Magnacharger on it is in need of
a new fuel module, it turned into a hard starter .
The original Walbro is still doing good suppling pressure
but the valve in the module has let go. It's at the dealership
getting a new module under warranty but the new
module is a little different than the one that came out of it.
The old module used a Walbro gss341, not sure for the new module
if theres a proper replacement for it?
Has any one run into this problem before?
Should I go with a Magna-volt and stick with the
new module/pump, and no Walbro replacement.
If I go with a fuel voltage booster should I be looking at
other manufactures like MSD, ect..
Thanks
Old Aug 25, 2010 | 02:14 PM
the_reaper's Avatar
If you go that route I have a brand new kennebell boost-a-pump kit never installed I will let go for cheap
DrX
Aug 28, 2015 08:50 AM
05GMC4.8
Aug 7, 2015 09:55 PM
bsgiffor
Jul 19, 2015 11:14 AM
GMCtrk
Jul 17, 2015 06:39 PM
