words of wisdom on sts purchase
Old Jun 23, 2010 | 07:26 PM
02'Z71ONDUBZ''s Avatar
Originally Posted by Ws6ickness
well the guy says its the original sts turbo outof the universal kit? guessing 67 mm? he says has all pipes clamps and etc. but since it wa set up for a tbi chevy truck im guesing i might have to cut some plumbing up!
You should really do a FMIC setup to keep IAT's down without the need for meth. If it was me, I would plan on buying a new oil pump regardless of the condition of the original, for the peace of mind. Fuel pump and 44lb injectors will run you around $350, and I would install a BOV as well.
Old Jun 23, 2010 | 10:52 PM
Ws6ickness's Avatar
i really dont want to do an inter cooler if not necessary, i dont really want a full out racer. just enough to get up and go in those times when you feel like hammerin down. are the injectors and fuel pump a must?
Old Jun 24, 2010 | 03:25 AM
casper02's Avatar
yes injectors and fuel pumps are a must u need fuel and an intercooler is strongly suggested even if ur not planning to race it
Old Jun 24, 2010 | 11:57 AM
You can add the intercooler which will fit right between the frame rails, and some charge piping which you will probably need anyway because you are fitting it on a newer truck, for around $200 off ebay. Yes you need the fuel system i listed to keep up with the turbo
Old Jun 24, 2010 | 12:18 PM
black04's Avatar
The stock fuel pump will probably be okay if you keep the boost under 8-9 psi
Old Jun 24, 2010 | 10:35 PM
Ws6ickness's Avatar
well i was planning on 8psi at most!.. but maybe a little higher if i go to the track.
Old Jun 25, 2010 | 06:10 AM
quicksilverado's Avatar
Not gonna happen.
Old Jun 25, 2010 | 07:04 AM
bud8fan's Avatar
Originally Posted by quicksilverado
Not gonna happen.
right...5 to 6# boost with stock pump at most...any more will result in a new motor....everybody has added their comments as to my first post on this thread...get a 255 walbro for $110 and some 60# injectors and a ic for safety because you will want more boost as you drive as it is very addictive...
Old Jun 25, 2010 | 11:24 AM
black04's Avatar
i run 7 with no problems. But a fuel pump is pretty cheap insurance anyways.
Old Jun 26, 2010 | 06:20 AM
bud8fan's Avatar
shure you can tune it to run anywhere...your prolly at 17* of timing at wot and down say 50-70 hp at 7 # boost compared to mine was at 450 hp at 8# with 26* of timing...thats where you need the extra fuel and injectors.
