Will Turbo'd Gibbs ever run again?
Old Jan 12, 2007 | 07:41 PM
  #41
hemidup's Avatar
TurboGibbs, You are a man of my own heart. I believe that I'm the first person ever, to modify a MP1 intake (That's a Dodge word) and incorperate it with a supercharger application. I also used a carb intake spacer between the throttle body and intake manifold to installed my w/m injectors into.
Old Jan 12, 2007 | 07:49 PM
  #42
Carrier2's Avatar
Hey, congrats man. Glad to hear you got it running . Maybe sometime soon, I can make it down there to see it
Old Jan 12, 2007 | 08:57 PM
  #43
TurboGibbs's Avatar
That's cool. Got pics?
I'm still having a little coolant leaking past the head gaskets tonight. I'm going to give it a few more heat cycles and see what happens. I checked the torque on the 1 head stud I can get to while hot and it was fine. didn't budge. I'll wait till it cools in the morning and check it again. I'm going to have to re-do my eboost2 sensing lines. There is a couple different ways you can configure them and currently with setting at 0 I can build 15 psi
Old Jan 13, 2007 | 04:56 AM
  #44
CurtD's Avatar
10 Second Truck Club
!5 psi..that's a good starting point for you Glad ya got it going, i'm wait to get my 342's and 1350 yoke installed. Then i'll start doing some tuning.
Old Jan 13, 2007 | 11:50 AM
  #45
TurboGibbs's Avatar
Well, I had ~ 3 qts of water in the oil. No steel on the mag drain plug and the amount of brg material in the oil filter is very little to none. Or nothing more than you'd expect from a first oil change. i'm really hoping and thinking that the water is leaking into the oil from the head gasket into the lifter area. I have a hard time believing that water would be leaking past the o-ring around the cyl. I'll pull the plugs and maybe that will tell me something and probably pull the pan. I think i'll start drinking before lunch today.
Old Jan 13, 2007 | 12:03 PM
  #46
kbracing96's Avatar
DAMN dude, that SUCKS!
I feel for ya
Old Jan 13, 2007 | 12:12 PM
  #47
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Damn Mark, fawking copper headgaskets
Old Jan 13, 2007 | 01:52 PM
  #48
TurboGibbs's Avatar
Well the oil pan is off and I checked #3 main brg and #8 rod and they look great so i'm going to put it back together, pull the plugs and check them and add some super duper stop leak. I used Moroso Ceramic Seal before with copper gaskets and had really good luck. You have to use it with pure water then drain after running and let sit. I may try something that mixes with antifreeze.
Old Jan 13, 2007 | 01:57 PM
  #49
kbracing96's Avatar
Just put a raw egg in it.... Worked on Mythbusters
Old Jan 13, 2007 | 02:06 PM
  #50
TurboGibbs's Avatar
Hey, i'd be willing to try just about anything to keep from pulling the motor.
corse ground black pepper is what they used in the old days. ......and eggs.
