Will The Stock Boosted 5.3 Hold????
Old 08-30-2006, 12:31 AM
  #31
Banned
ogkevin13's Avatar
ok koo what b/c should i use and meth kit?
Old 08-30-2006, 10:03 AM
  #32
How do I change this text
Wilde Racing's Avatar
You don't need the valve spring if your engine is low mile 5.3 @10 psi. Or atleast I didn't.
I had 60,000 on my 5.3 before I isntalled the STS kit and ran it at 10-12 psi for about five months before # 7 went lean.
Instead of valve springs, I'd rather have a better intake. Now if it is a 6.0 then you need valve springs.........
BTW my 44 lb injectors did just fine on the 6.0 (and 5.3) with no meth at 12 psi.......
Old 08-30-2006, 10:14 AM
  #33
8 Second Truck Club
Blown06's Avatar
Everyone knows my #7 broke in two days with a tune from MTI.
Watching the scanner on the dyno:
12# boost
0 kr
11.1 afr
Might be looking for a new tuner for the next motor.
Old 08-30-2006, 11:46 AM
  #34
slowec's Avatar
I would like to see the injectors on these "#7 lean motors" have a balance test performed. I have seen alot of #7 injectors clogged on stock vehicles I worked on at the dealership.
Old 08-30-2006, 12:41 PM
  #35
8 Second Truck Club
Blown06's Avatar
My new 44lb racetronix injectors had about 100 miles on them when the engine let go, so I doubt they were clogged up.
Old 08-30-2006, 01:07 PM
  #36
slowec's Avatar
N.E.W. = Never ever worked. Dirt and crap in your gas don't care how new your injectors are. Just sayin its worth lookin at.
Old 08-30-2006, 04:00 PM
  #37
Banned
ogkevin13's Avatar
ok so valve springs aint needed at 10-12 psi i still want to run meth and i/c to be safe. wilderacing ur blow ur motor dew to ur vsprings? and am ganna use the side mount i/c under the passenger seat i think its the one u sold to xerox!! is that a good i/c i want to run 8 psi low and hoping i can go 12 psi at the track
damm i might want to drop the gas tank and clean it then!!!
Old 08-30-2006, 04:25 PM
  #38
What?
My 5.3 cracked #5 and # 7 pisions, It WAS NOT the injectors being dirt because I'm still using the same injectors on the new eng.
Old 08-30-2006, 04:54 PM
  #39
Banned
ogkevin13's Avatar
what waz the reason for those 2 pistons 2 give out? were they the valvesprings?? u think ill have n e problems wit my set up? 5.3 (stock) 44lb injectors, pump, side mount i/c (will it work for 10-12 psi?) and meth?????
Old 08-30-2006, 05:11 PM
  #40
vanillagorilla's Avatar
Can I get some specifics from you guys that actually have had piston failure. Where specifically did it fail? Ring land? Pics?
I've been running 10psi for quite some time now on my 4.8. I've even run WOT very lean on more than one occasion. I'm wondering if the 4.8's flat tops are inherently stronger than the 5.3" dished pistons.
Quick Reply: Will The Stock Boosted 5.3 Hold????
