Wideband logging through EGR
Old 01-31-2018, 06:43 PM
FFDP's Avatar
Should be the white wire.
All my other AEM's were the white wire.
Old 01-31-2018, 06:46 PM
ILuvJDM's Avatar
Great, thanks
Old 01-31-2018, 09:57 PM
vettelovralexand's Avatar
So, in conclusion: read the very first response for every answer in the thread.
Old 02-14-2019, 07:16 AM
05GMC4.8's Avatar
Bumping an old one, but was this for a nnbs pcm? Im wanting to do the same
Old 02-14-2019, 08:28 AM
FetzerValve's Avatar
Yep, NNBS ECM. E38.
05GMC4.8 (02-14-2019)
Old 02-14-2019, 08:42 AM
05GMC4.8's Avatar
10-4. I found a wiring diagram and it shows pin 55 being not used. Does something need to be activated in the ecm for hptuners to see this input?
Old 02-17-2019, 03:30 PM
rjm27's Avatar
I wasn't able to get this to work.. pin 55 on E38, 2008 Silverado RCSB. No data in hptuners
Old 02-17-2019, 09:18 PM
Jonblarc7's Avatar
Wouldn’t be easier just to get a wideband with a serial out to plug it into your USB port on your laptop. If your using standard HP tuner
Old 02-17-2019, 09:37 PM
FFDP's Avatar
Or the OB2 wideband that AEM sells.
Haven't tried the EGR trick on the E38's, only the P01/P59 have I done it before.
Old 02-18-2019, 07:40 AM
03sierraslt's Avatar
The OBD2 wideband only works on newer Can based ecms. Like 07-08 up
Quick Reply: Wideband logging through EGR
