-   FORCED INDUCTION (https://www.performancetrucks.net/forums/forced-induction-159/)
-   -   wideband help!!!! (https://www.performancetrucks.net/forums/forced-induction-159/wideband-help-468824/)
gmc6.0 Sep 10, 2010 12:31 AM
wideband help!!!!
i recently installed autometer coablt wideband and i cant get it to work i follwed the directions to a T but it dosent display my afr. i turn the ignition on and the gauge lights up i wait awhile turn the truck on let it idle and i see the numbers go from begining to the end then it turns off no error codes or anything i already replaced the harness once any ideas?
terravast4 Sep 10, 2010 12:54 PM
What about the 02 sensor?
gmc6.0 Sep 13, 2010 11:16 PM
the 02 sensor is brand new and looks like it to....i called autometer and they said that i need a new power and ground source and not to hook it up to another gauge can anyone help who has installed a autometer wideband where do u hook your up to
03_Denali Sep 14, 2010 07:22 AM
I think Terra was referring to the correct 02 sensor to read wideband. It needs a Lambda Sensor. One should have came with the kit.
bai78 Sep 14, 2010 08:13 AM
Mine is powered by the side panel fuse box. It is "t" into the correpsonding amp source.
Bluecobra Sep 17, 2010 04:43 PM
You need to run an independent power and ground to the gauge. I learned this the hard way trying to tie my AEM WB into the existing power and ground for the other gauges. The sensor needs a bit more power and doesn't like to share - so to speak.
gmc6.0 Sep 18, 2010 12:36 AM
okay so how did you wire yours bluecobra, after contacting auto meter they said the power and ground cant be tied into the other gauges because it needs power to warm up the sensor...i tried hooking it to the battery same thing but the truck was off any other ideas...
gmc6.0 Sep 18, 2010 01:17 AM
where does everyone draw their power for the wideband and where do you ground it at.....
AKlowriderZ71 Sep 18, 2010 01:23 AM
Is the entire gauge blank? Or do you see --- instead of numbers?
gmc6.0 Sep 18, 2010 01:32 AM
yeah when i first turn on the ignition it shows -- then i wait for a mintue turn the truck on and it does the count down after that all the leds shows up and the numbers turn off then the whole gauge shuts off...
