wich of this turbos for a stock 5.3L
Old Jan 23, 2013 | 03:15 AM
400ss's Avatar
Default wich of this turbos for a stock 5.3L
im working on my 1993 LS powered Ford lightning
I want to build a turbo kit for my truck,
wich of this turbos will work on my aplication???? It has a stock 5.3L engine, i want to make like 9-10 PSI of boost, its my daily driven car
This are the specs on the turbos, let me know wich will work better for my truck..
FIRST:
Intake :4 inch
Outlet: 2.5 inch
Compressor trim: .70 ar
Compressor Wheel diameter: 66.71 /84.20
Turbine wheel diameter : 63.56 /73.60
Exhaust trim: 1.00ar
SECOND:
Intake :4 inch
Outlet: 2.5 inch
Compressor Wheel diameter: 61.52 /81.20
Turbine wheel diameter : 68.00 /62.32
Exhaust trim: .84 a
THIRD:
Intake :4 inch
Outlet: 2.5 inch
Compressor Wheel diameter: 66.36 /81.87
Turbine wheel diameter : 64.50 /73.60
Exhaust trim: .82 a
ANOTHER QUESTION ABOUT THE FUEL SYSTEM, TRUCK ALREADY HAVE DUAL 255 WALBROS PUMPS, CAN I FEED 9-10 PSI OF BOOST WHIT 8.1L MARINE INJECTORS ( the ones used on the magnacharger kit)
LET ME KNOW PLEASE AND THANKS IN ADVANCE
Old Jan 23, 2013 | 05:25 AM
Suburbazine's Avatar
I think they might be a bit on the small side.
Old Jan 23, 2013 | 07:14 AM
silver-mod-o's Avatar
Hunt&Fisherator
Looks like any of those will be tapped out by 10psi, and so would the injectors.
Old Jan 23, 2013 | 10:11 AM
smokeshow's Avatar
Mod with training wheels
If really all you want is 10psi, i'd do the 3rd one... i have run those injectors to 10psi on a 5.3 and yes, they are about maxed out. Might be able to get by. You'll have no room for overhead though.
Old Jan 23, 2013 | 10:13 AM
jjc839's Avatar
I have 44's in a stock 5.3 @ 7psi, and they are already at 77% duty cycle. I think marine injectors are 42's(?) so ya would probably be maxed out.
Old Jan 23, 2013 | 12:02 PM
M&M Turbochargers's Avatar
id shoot for about a 72mm compressor inducer and a turbine wheel no smaller that 74.2/67mm
Old Jan 23, 2013 | 12:34 PM
400ss's Avatar
thanks everyone, i really dont know how to choose the turbo size. i want to use the marine injectors for the moment, so maybe i will run 7 PSI then. i want to run one of those GODSPEED turbos for the moment, then i will upgrade to a good brand one, does anybody can help choose one of those godspeed turbo??
I atached some pics of my truck
Attached Thumbnails wich of this turbos for a stock 5.3L-23012013405.jpg   wich of this turbos for a stock 5.3L-23012013406.jpg   wich of this turbos for a stock 5.3L-23012013407.jpg
Old Jan 23, 2013 | 01:47 PM
gamble686's Avatar
Why not try one of the On3 turbos? The 76mm Jb is like $400 shipped and at least one member has gone 10s on it.
Old Jan 24, 2013 | 12:42 AM
400ss's Avatar
What do you think about this one for 7-9 PSI???
Cold Side:
Compressor Wheel 76mm
.80 a/r
4” Inlet and 2.5” Compressor Outlet
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
Exhaust Housing T-4 Flange
.96 ar Exhaust Housing (.68, .81, 1.0 divided, 1.15 divided $30 charge for swapping housings)
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 65mm
Old Jan 25, 2013 | 11:34 AM
400ss's Avatar
Anybodyy? thanks everyone
