Why I loose 3 to 4 lb's of boost?
Old Dec 10, 2014 | 01:26 PM
Choda's Avatar
take the controller off and run it on the spring alone.
report back what happens and try to get a video of your boost gauge
Old Dec 10, 2014 | 04:19 PM
urdone's Avatar
Originally Posted by Atomic
Actually it sounds like you have a boost spike issue. 5lb spring should be 5lb of boost. The fact thst it returns to that means its working just fine and you have your gate open pressure too high.
Ok so maybe I need a stronger spring, I order new springs already Ima try the 8 lbs spring and turn up the controller to see what happen.
When I did't had the controller it was at 5 lbs and i remember the boost dropping to 3 lb's but I though since it's only 5lbs at top it was loosing boost.
But now on 10 lb's and loosing 4 lb's don't look right to me.
Old Dec 11, 2014 | 02:38 PM
GRRR65GTO's Avatar
Well jgs doesnt rate their springs by lbs they go by size so where are you getting these numbers from?
I have all three
Light makes 4 lbs
Medium makes 7 then drops to 4-5
Heavy made 15 and that was too much
Old Dec 14, 2014 | 06:44 PM
urdone's Avatar
I just got it and it was the red one soft, but i lost it lol.
Ordering another one, can i insert two the soft one and the medium one like the precision wastegate?
Brandonlflr12
14
Sep 16, 2015 12:44 AM
2500ZL1
Sep 12, 2015 03:50 PM
sTNT971
Sep 11, 2015 02:38 AM
Pimpinpete
Sep 8, 2015 07:39 PM
06murder
Sep 4, 2015 03:54 PM
