While we are reviewing cams.....
Old Aug 7, 2015 | 04:12 PM
DrX's Avatar
DrX
I'm thinking that the present lift also exceeded the recommended max for the stainless valves that were originally installed in the heads. Original build sheet listed lifts as .5XX, which is where they would have been with 1.7 rockers. The difference turned out to be exactly the difference between a 1.7 and the 1.8 (LS7 style) rockers that were used.
So what would be the ideal characteristics of a head for this application?
Old Aug 7, 2015 | 08:53 PM
George C....'s Avatar
Formerly ScreamingL
I know they are a lot greater, but they also have a large bias in flow to the intake side. Characteristics the LS3 displays too. I was trying to say that a cam that would work great in a cathedral head application wont work as well here.
i have the cathedral mast heads and my cam is split as well since the exhaust port is ls7 based...something to think about
Old Aug 7, 2015 | 08:54 PM
Formerly ScreamingL
fyi my intake is 2.25 and its stainless, my exhaust is inconel and i posted my lift with 1.8s
Old Aug 7, 2015 | 09:33 PM
DrX's Avatar
DrX
That's a big valve. I was looking at various heads and one of them did not recommend stainless with over something like .613 lift. Could have been PRC, but not certain. What springs/spring pressures with those?
Old Aug 7, 2015 | 09:36 PM
Formerly ScreamingL
they said 700 lift springs, i told them my cam specs and they set the heads up for me
it is a big valve on a big head, they are the 295cc mast heads
curious if you had simialr heads what was your pushrod lenght? mine are 8" with my tie bar lifters
Old Aug 7, 2015 | 10:47 PM
DrX's Avatar
DrX
Hmmm..... original invoice says "LS1 push rods Comp Cams." Build sheet said "Smith Bros 5/16" x 8.075"
Current build sheet says TFS-21408050 (8.050") Pretty sure what I just pulled out was the Trick Flows. Non tie bar Morel hydraulic rollers.
Old Aug 7, 2015 | 10:50 PM
Formerly ScreamingL
that makes some sense, my lifters require only .030 preload and my block was decked
8" long
3/8" thick
.134 wall thickness
wonder if your setup was flexing those pushrods, said anything over 7.5 ya should have 3/8 if you have the clearance especially with that valve train
Old Aug 8, 2015 | 10:05 AM
Vortec350ss's Avatar
Are you running stock rockers? The problem tends to be in the way the rockers pull at the valves over certain lift. The LS7 style rockers done have the same problem until much higher lift numbers.
George that exactly my point on the cam. It's not the split specifically i don't like, it's that the exhaust open is far too late for these heads. Especially at his boost level.
Old Aug 8, 2015 | 10:09 AM
DrX's Avatar
DrX
Thinking that if I was comparing heads, I should be looking for better exhaust flow.
I'm running Crower SS shaft mount rollers
Old Aug 8, 2015 | 10:23 AM
DrX's Avatar
DrX
I see their spring options include ".700 lift" and "turbo" Not that they ever have any LS7 style heads available.
Seems that many feel that my spring pressures were too low for 20 PSI/7000 RPM...currently at 155/450
