what turbo?
Old Apr 1, 2013 | 07:24 AM
If you want cheap, I would suggest this GT45 Huge V Band 1000 HPS Turbo turbocharger Camaro GT | eBay over the on3 turbo. Ive seen lots of problems with on3. If you want to spend a little more, I would say BW S475 with 83mm turbine and 1.10 ar T4 housing. Forcedinductions.com can set you up with one of those
Old Apr 1, 2013 | 08:27 AM
darnie's Avatar
what about this one ?
http://forcedinductions.com/productsborgwarner.htm
S300-64 ETT
750HP
68mm, 71mm, 73mm A/R
.88 .90, 1.00 T4
$749
Old Apr 1, 2013 | 08:31 AM
too small. Call Jose @ forcedinductions. He will prolly suggest the same turbo I did. T4 S475 with 83mm turbine and 1.10 ar. Should be under $800
Old Apr 1, 2013 | 09:17 AM
darnie's Avatar
ok cool, ill have to hit them up. i wouldnt mind running the ebay one, but im a bit skeptical buying stuff off there as far as quality goes...
Old Apr 1, 2013 | 09:36 AM
Yea you wont be able to BW quality but if budget is what youre looking for you cant go wrong with the one I posted. Im running the 80mm version of it and its working perfectly
Old Apr 1, 2013 | 09:37 AM
darnie's Avatar
called them, $850 witch isnt to bad.
Old Apr 1, 2013 | 10:24 AM
nonnieselman's Avatar
S475!!
i love mine!!
check with our sponsors too! I got mine from KBracing
Old Apr 1, 2013 | 10:43 AM
fortplainman's Avatar
why not use a s468 like silveradol33 did? he made 681rwhp on a 5.3. its smaller than the s475 and anything that i have read it would be less laggy which is what you are looking for.
https://www.performancetrucks.net/fo...inside-438317/
Old Apr 1, 2013 | 11:29 AM
Thats true.. i didnt think about that.. but keep the 83mm turbine for some top end?
Old Apr 1, 2013 | 12:59 PM
gamble686's Avatar
He has an 80e with a good stall, 3.73s on 33" tires, a fairly built up 5.3, and a heavy *** truck I have a feeling building boost won't be tough. LOL
