What trans cooler with 4" trick race IC
Old Jul 1, 2014 | 07:39 PM
  #21
oakley6575's Avatar
Originally Posted by LPCWS6
I'd have to go look at my truck again but I don't think the NBS trucks have as much room between the A frame and AC condenser compared to the NNBS trucks to mount the trans cooler the way Choda did.
Yea I looked again earlier and there is only an inch or less there. Might be able to space the top A frame mount out and stick the cooler at the very top behind the A frame but I still don't think it would clear.
Old Jul 2, 2014 | 03:06 PM
  #22
hsiriyob's Avatar
the a-frame touches the condenser on nbs. Just ordered this ic from rick. there appears to be two spots to mount. in front of the ic or between condenser and rad. Im having trouble finding the thread/pics of the cooler between the cond/rad. anybody know the thread?
Old Jul 2, 2014 | 03:33 PM
  #23
TrickTurbo's Avatar
Truck Sponsor
If theres room.
Mount it infront of ic.
Behind ic is the second location.
Old Jul 2, 2014 | 03:48 PM
  #24
oakley6575's Avatar
I'd be interested to see that thread
Old Jul 2, 2014 | 04:28 PM
  #25
Denali08's Avatar
I didn't see any pics of the tru cooler in front. I see this pic of the cooler pressed in between the IC and A frame....?
https://www.performancetrucks.net/fo...-514778/page4/
Originally Posted by TrickPerformanceProducts
The pic I see shows the IC moved forward.
And the trans cooler against A frame.
So if the ic was against the A frame.
The trans cooler could fit in front.
That was initial install. It was relocated later to the front of the IC. IC was moved back against the A-frame.
https://www.performancetrucks.net/fo...514778/page10/
Old Jul 2, 2014 | 11:05 PM
  #26
hsiriyob's Avatar
I've seen that you've posted in a couple of threads regarding this. My thought is since I'm by passing the rad it should be ok inbetween the rad/cond. I also see that rick with trick keeps pushing for it in front. I just don't want to hide the ic. Does that make me vain lol
Old Jul 2, 2014 | 11:14 PM
  #27
LPCWS6's Avatar
Probably because his mounting brackets that come with his IC's won't work if you put it between the A-frame and the IC.
Old Jul 3, 2014 | 09:47 AM
  #28
TrickTurbo's Avatar
Truck Sponsor
Why won't they work?
Just drill a different hole as needed.
Old Jul 3, 2014 | 06:10 PM
  #29
LPCWS6's Avatar
They might work. I already dropped most of my stuff off at the shop so I can't just go look but I don't think there is enough room to drill another hole in brackets to move the IC forward another 1 1/2 - 2". It wouldn't be hard to get some sheet metal to extend them out a little though. Either way once my truck is done and everything is installed if the shop doing my install makes it work out nicely I'll take a few pics and post them up. If it's all duct tape and zip ties then I'm keeping that to myself.
Old Jul 4, 2014 | 10:36 PM
  #30
hsiriyob's Avatar
I hope it turns out well so we can get some pics.!
ullose272
Aug 5, 2016 02:05 PM
1slwgto
Aug 16, 2015 06:40 PM
zaathur151
Aug 12, 2015 06:32 PM
Ls3silverado
Jul 31, 2015 04:22 PM
ferrellrooster
Jul 17, 2015 07:07 AM
