What the...? More boost after bigger exhaust?
Old Jun 16, 2013 | 09:39 PM
swift700's Avatar
Default What the...? More boost after bigger exhaust?
This weekend I switched from a single 3" to a single 4" exhaust system. I had never seen more than 9psi of boost with my old exhaust but after the swap I'm seeing almost 11.
I thought the boost would go down, seeing as there is less restriction after the engine. Help me figure this out.
Old Jun 16, 2013 | 09:54 PM
Random User's Avatar
Backpressure was choking it down
cjlee13's Avatar
Registered User
I'm sure its normal since youre freeing up more gasflow from the turbo.
Old Jun 16, 2013 | 10:00 PM
swift700's Avatar
It's a supercharger, and I thought boost was a measurement of restriction. If there's something backing up the flow of boost, it should climb higher. If the restriction is less, the boost should drop, all else being the same.
Old Jun 16, 2013 | 10:03 PM
Hell...I was thinking turbo myself. I gotta start reading Sig's more.
Old Jun 16, 2013 | 10:26 PM
cjlee13's Avatar
Registered User
Just saw your sig says SC.
Hummm interesting... I also think you should see less with SC since there is less restriction in flow.
Old Jun 16, 2013 | 10:32 PM
swift700's Avatar
Yeah, I'm starting to think it might be coincidental. I changed my plugs at the same time and found one to be black with carbon. I'm thinking maybe there's a valve problem in that cylinder... maybe a weak lifter. If that exhaust valve isn't opening properly then it would create some extra backpressure. OR maybe not. I'm just trying to figure this out.
Old Jun 16, 2013 | 10:43 PM
kelsey_canard's Avatar
If the exhaust valve doesn't open, the compression feeds back into the intake under scenarios I've seen. A lack of being able to get air OUT of the motor would cause for an increase in restriction/boost in my experience. If the exhaust valve decided to stay closed AFTER the exhaust change, then I could understand it. Although, that sounds like a coincidence.
Old Jun 16, 2013 | 10:56 PM
cjlee13's Avatar
Registered User
Possibly.
You shouldn't see boost gain after changed bigger piping exhaust. Must air stuck around in manifold or some.
Old Jun 16, 2013 | 11:00 PM
Originally Posted by cjlee13
Possibly.
Wouldn't that drop boost? The manifold pressure would be higher than atmospheric, causing a boost leak.
