what is the difference bws375 vs s475?
what are the differences?? I figured its a small frame but would that limit the size of the exhaust wheel?? and limit the A/r choices ?
tia
tia
I'm running a S480 with a 1.00 a/r T4 83mm turbine wheel on my truck and love it. When the same time and speed on this turbo at 11psi as I did with the Magunum bb 72 at 15psi.
I wouldn't be afraid of a .90 a/r on a 83mm wheel. That's still a high flowing exhaust housing compared to a TC76-78 with just a little 68mm wheel and a .96 a/r. A/R is just a ratio of the T4 inlet and the turbine wheel outlet, not a measured size like the turbine wheel,
To give you an example, these are both .96 a/r T4's, the left is a PT88 with a 94mm turbine wheel and the right is a MP T76 with a 64.5mm turbine wheel. Same a/r, See the difference?
