What boost controller are you running?
Old Sep 6, 2006 | 05:31 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Z06 DREAMING
off topic but, are you going to be boosting that 418?
Why yes, yes I will
But it wont be just boost going through the Vic Jr intake
Old Sep 6, 2006 | 05:32 PM
1slow01Z71's Avatar
Looks like Im going to go with the STS 2 stage 15psi setup for now, till I up the boost past 15
Old Sep 8, 2006 | 09:25 AM
DrTurbo's Avatar
LS1TECH Sponsor
We use E-boost 2 on almost all the setups. Works perfect, and its user friendly if you read the instructions. Nothing to it.
Old Sep 9, 2006 | 07:08 PM
parish8's Avatar
single digit dreamer
i have the blitz sbid or something like that. it was stupid expensive. like $700 but i dont remember for sure. it is easy to use, looks cool and has a ton of features. i have had no problems with it at all.
the best thing about it is the speed based boost control. you can set up 4 diferent boost levels and have the unit decide when to pick each one based on mph. i run about 10psi off the line, 12psi kicks in around 40mph and at 60mph(after the 1-2 shift) i kick it up to whatever my max boost for that day is.
Old Sep 9, 2006 | 07:29 PM
1slow01Z71's Avatar
I likey
Im going to do a bit more research on the blitz.
Old Sep 9, 2006 | 07:47 PM
1slow01Z71's Avatar
How does the Blitz mount? Got any pics of it installed?
Old Sep 9, 2006 | 07:55 PM
parish8's Avatar
the control unit just sticks to any flat surface you can find but there are not a lot of flat spots large enough to mount it.
it has a read out of mph and current boost. it also has a read out of max boost on past run. it will give hp if you dont have a traction problem. it will read in bar and psi. it is suppose to be able to set an actual boost level and it will go there but i never really tried that. there is a gain setting wich controls how hard it brings the boost on but if you set it too high there may be a little over boost.
Old Sep 9, 2006 | 09:35 PM
1slow01Z71's Avatar
They dont make a mount for it? I dont have a place to mount it like you did.
Old Sep 9, 2006 | 09:41 PM
parish8's Avatar
when i had it on the dash i took a piece of 1/8" thick plastic about 1" x 6" and stuck that to my dash over the air bag switch area and then stick the unit to that. all i used was 2 sided 3m tape to hold it up there. the reason you need the back piece of plastic is what you see there is actualy 2 seperate pieces but they need to be next to each other to work.
i ran the wires thru a hole in the air bag switch area. it looked ok but not great. i would just hide it in the glove box or maybe try and make something to put in the over head council.
Old Sep 9, 2006 | 09:46 PM
1slow01Z71's Avatar
I may make something ot hang down by the rear view or something, I really like the features of the Blitz over the eboost plus it looks better.
