Well so far not good....
Yah everything tights on it... I could drive it around a little all the hoses are tight... So any chain autoparts store should have the tools to do this right?
I hope its simple lol.. turbo sounds great just sluggish right now...
Glad to hear the truck is running, and bad to hear you are having issues.
Check all electical connections, if the maf was unplug it will run like junk, but just for a little bit, then it will smooth out idle. At least mine did.
Check plug wires, these trucks will run with only 4 wire on. Yes it happened to me.
Vacuum ports are a big one, and that relearn, I know that freaked me out, took several starts to get it to clean up. After we switched out the pcm it took a little bit to get it cleaned up.
well like a dumbass i left the coil packs unplugged on the drivers side... in my rush i was running on 4 cylinders.... But got that fixed and it still doesnt want to idle it keeps dying on me... also have some oil leaks to run down...
Keep restarting it, the coil pack off the truck learned how to keep its self running..on 4 cylinders, also check your inecjtors plugs.
