wastgate ??
Old Oct 15, 2007 | 05:00 PM
05crew's Avatar
Default wastgate ??
are there trucks out there that run just the wastgate spring with no boost controller. im ordering some stuff from TRT and thay are telling me that i can do that. not saying he is not right because they know there ****!!! but im have a lot of trouble form my greddy boost controller, and getting tired of it!!!
Old Oct 15, 2007 | 05:05 PM
parish8's Avatar
single digit dreamer
sure you can.
i have a tial wg. you can get springs for $30 each. the boost range is from something like 3psi up to 20+ in about 1.5psi steps. just pick your spring.
Old Oct 15, 2007 | 05:59 PM
TchargedLS1TA's Avatar
Im running a 5 psi spring in my wifes 5.3L. WOT it will hit about 6psi, sometimes I will see 7psi spikes. No boost controller whatsoever on a stock STS kit
Old Oct 15, 2007 | 06:04 PM
WJ MARK's Avatar
Im runnin 10 psi spring, sometimes it hits 11 psi or maybe my guage is off alittle. Had a controller on there but took it off to see if there was any difference as far as how quick it builds boost.
Old Oct 15, 2007 | 09:41 PM
alanderson1978's Avatar
I've got a 3 pound spring in mine. I've seen close to 7 now that I have gotten brave. I've had mine for about 2 months, and I just hooked up the boost controller this weekend (Apexi AVC-R) and it looks like it's doing what it's supposed to.
Old Oct 15, 2007 | 10:26 PM
05crew's Avatar
i understand i can do that, has yall ever seen you boost jump with ever gear you hit and keep climeing with the more RPM you turn? i can trun my boost controller off and see 5 psi with very bad boost spikes, up to 10 psi and climeing!!!
Old Oct 15, 2007 | 10:35 PM
parish8's Avatar
hmm. most of the time the boost level doesn't hold exactly steady. sometimes it spikes up a little and falls as rpms rise but on other set ups it will rise as rpms go up but going from 5psi up to 10psi is too much of a change. gate might be too small for the motor size. gate might be plumbed wrong.
Old Oct 15, 2007 | 10:54 PM
Slowhawk's Avatar
LS1Tech Sponsor
Just having a controller hooked up can cause boost spikes if you don't run a bleed valve.Just run a boost reference hose to the wastegate and leave the other port open.It should hold steady.If it creaps up with rpm then the wastegate is too small or there is an exhaust restriction.
Most of the time I run 7lbs off the spring and it might jump to 8lbs on a shift.Then I have my $8 manual boost controller that a simple turn put's me at 10 or 14lbs if I like.
Old Oct 15, 2007 | 10:57 PM
With the boost controller, I just see some spikes (about 1 PSI). But the 3 psi spring would allow up to 6-7 PSI regularly during WOT. I figured it's just the wastegate is not big enough to flow THAT much exhaust around it.
Old Oct 16, 2007 | 06:30 PM
05crew's Avatar
can u have to big of a wastgate? i think mine is a 38mm, might not be 38mm is in my head.
