Want to built turbo setup for a 4.8
#21
and honestly, id do teh LS6 cam before the LS9 cam.. the LS9 is too soft down low.
or go ahead and get a isky custom grind like the triple 12, gives you a good bit of low end where you need it and makes for a great DD cam.
#22
i'd start w/ tranny (4l80e)and good lsd (trutrac etc). be able to get the added power down and not break ****. than start added more power. like said isky has some bad turbo cams or the ls6 cam. throw some good valve springs in there. i run Patriot dual golds but there are other options. i made 440rwhp on 8# and thats all you need on the street.
#26
A little confused by this statement. I'd like to keep the 5 speed if that's what your asking, is the trans that i have so bad? Can i not build it up or is the 4l80e just that much better?
#28
the NV3500 (if thats what you have) doesnt like to be shifted to fast especially at high rpms. Atleast thats my experience with them.
If you wanna stay with a Manual trans, go with a built T56?
#29
t
i had really good luck w/ mine holding up, but its awful to shift. its even worse the more power you start sending thru it. t56 would be the best manual. if you like shifting get a 4l80 w/ manual valve body. i'd never go back to the 5 speed. now running a manual th400. you will probably want OD tho.
