VGT turbo
Old Feb 3, 2012 | 03:22 PM
camperhead's Avatar
Default VGT turbo
So has anyone tried using a holset VGT turbo? there are a couple different makers of controlers so you can put one on a older style diesel... Gives the best of both worlds... And im talking on a everyday driver..
Old Feb 3, 2012 | 04:02 PM
slow67's Avatar
Gingervitis Addict
There are some small 4cyl guys doing it....I think twin he351VE turbos would be perfect for a 4.8L-6.0L.
Old Feb 3, 2012 | 08:01 PM
kbracing96's Avatar
I was gonna try and build a twin setup with those turbo for my truck before I did my last setup. Talked to Fleese about there controller and they told me at that time it wouldn't work on it's own, needed to be used with the older Dodge diesel PCM. It's also like $600 and I'd need 2 of them plus those turbos are around $350 used on eBay so was gonna get expensive fast. I just decided to do a conventional setup instead. Something I would still like to try though.
Old Feb 3, 2012 | 11:31 PM
01GMC5.3's Avatar
I bet if it worked right it would make for one hell of a ride
Old Feb 4, 2012 | 11:54 AM
slow67's Avatar
Gingervitis Addict
Do a mechanical setup. Very cheap.
Old Feb 6, 2012 | 08:22 AM
camperhead's Avatar
I came across some 4cyl "tuners" guys controlling it with rod style waste gate actuators. That would definable lower cost of the build... I need to finish the lengthy post about it to finish it up to find out if they got good control...
Old Feb 6, 2012 | 02:31 PM
slow67's Avatar
Gingervitis Addict
You could also just use a spring, as backpressure already tries to open up the rack.
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
