Very Frustrated
2nd fastest 5.3 ECSB
Inststalled the new meth controller this afternoon! I haven't been in boost since the 18th of Nov., and had almost forgotten how good it feels to chirp tires at 50mph.
Unfortunately the moment lasted about 15 minutes before losing the meth again!! The indicator doesn't light and it goes way lean as I go into boost.
I know we'll get this all figured out, it's not that big an issue comparitively speaking, but it's still frustrating having to drive my truck like a Volvo.
Hopefully you'll just find the pump ground loose or something simple. If it worked at first, then it shouldn't be a hardware issue. I think you'll solve it fairly easily.
i am not sure i am following the problem, but check all connections. Remember, it's an electrical switch...no load...then load. So if you have a weak connection it can break once load hits it. After that, tuning in meth with 2bar isn't as easy as just hooking it all up IMO, if getting the meth 'delay" to work into your tune is a concern. BUT ofcourse, you have a pretty decent tuner to the say the least. LOL
****ahhh, re-read...yep, check those connections, triggers, and such****
Sorry to hear about your problems Bill. I know how frustrating things can get. At least it just a controller/wiring issue and not something serious mechanically. I am sure that Rick/Julio will be able to find out the problem and get you on the road to lower in the 12's.
Thanks Jason. I know it will be resolved soon, just waiting is like my life is on hold....
Dropping it off this afternoon and leaving it with the guru's of electronic devices. Damn, and this great weather were having too!
When you want to head back to Sac?
Is meth the only way you can make boost???? What are your fuel upgrades???? I would suggest upgrading that fuel system to allow you to run boost all the time.
On another note. Did you run a check valve on your kit??? I was having a problem with getting the meth to flow fast enough when running 18+lbs.
it just stopped working.
