Twin turbo build ??
Alright I started a new twin turbo build and have a few questions to ask.
First off turbo oil drain location. Do I tap each side of the pan for the return bung or can I tap 2 fittings into the timing cover?
Oil fees lines, do I use the original oil cooler block off plate tap it and run a y fitting to feed both turbos or is there a different way to do so?
Turbo size, set of on3 70mm turbos too big?
I'm looking to make max possible power on a stock bottom end cam only 4.8 track only truck. I have a Trans brake installed and can use nitrous if needed to help spool the turbos.
Any advice or tips much appreciated thanks in advance
Not much clutter left under the hood right now everything stripped out. No a/c or power steering, electric water pump, alternator and PCM relocated. I had started with a single s475 kit but I changed direction to twins since I have all the room anyways. The single kit will be used on another truck though but so many single turbo 4.8s I wanted something a lil different lol
I think you will go faster on a single log turbo if you got a trans brake, if you could take off with 15psi and hold 25 throw the hole pass on s480 billet wheel 1.10 you should get mid 9s. If your set on twins then get 62mm turbos with 64mm ex with .68ar
