twin gt3076 to small for 4.8?
Turbos | Superchargers | Intercoolers | H2O/Meth Injection
03-14-2014, 01:19 PM
nosho47
If I run a twin gt3076r turbo, will I be able to get near 700hp with a good tune for my 4.8? Would you guys recommend the gt3076r or gt35r?
Like
nosho47
Find More Posts by nosho47
03-14-2014, 01:36 PM
smokeshow
Mod with training wheels
30r will be plenty.
Like
smokeshow
Find More Posts by smokeshow
03-18-2014, 09:25 PM
nosho47
How much psi will I need to get to 700hp?
Like
nosho47
03-18-2014, 09:39 PM
smokeshow
Depends on the cam and other things....but probably around 18psi.
Like
smokeshow
03-19-2014, 06:38 PM
nosho47
Will running that much boost on a isky triple 12,cam, 60# injectors, walbro 400 fuel pump and 2800 stall converter be able ok?
Like
nosho47
03-19-2014, 06:45 PM
timmay208
going to need more than 60lb injectors if you want to make big power
IMO that turbo is to small but it would spool fast
Like
timmay208
Find More Posts by timmay208
03-19-2014, 06:53 PM
smokeshow
I've run SD60 injectors with an E50 mixture at 22psi shifting at 6800 with no issue. Isky 218 cam.
Like
Low volts
My new project. Started with fuel pump replacement....
Plastic Piece Broke Off ECU Mounting Bracket
'07 4L80 and 246 Transfer case into an '02 Silverado
2001 SCSB 4.8 4x4 to AWD swap
78
120.5k
smokeshow
03-19-2014, 07:08 PM
timmay208
60lb injectors but what base pressure and duty cycle? That is pushing them
Like
timmay208
03-20-2014, 12:15 AM
smokeshow
Quote:
Originally Posted by
timmay208
58psi made them 73lb. Duty cycle was high 80s. Was enough power to leave 600cc bikes in the dust
Like
smokeshow
03-21-2014, 02:54 AM
nosho47
Is that safe I don't want to blow anything up especially since my Tahoe is a family car
Like
nosho47
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
03:43 PM
