TVS2300 Front Inlet/Rear Cog Drive
#21
FormerVendor
wow looks phenominal Joe - very impressed. Im going with the same setup, but in the chrome finish... would love to use the ARP Bolts, did you get the bolts individually or was it in a kit? Id like to do the same, they are building my unit this week (hopefully).
did you overdrive your pulley? what size is your front pulley?
I am over-driven both front and rear and we are unsure of what pulley will be needed on the front to reach our boost goals.
#22
When you do your testing could you please do a couple of runs at the 8-9 psi range. It would be really interesting to see how a built 6.0L with the L92 heads does compared to the LS3 at a similar psi. I know that there are many differences in cam, drive line losses vs nelson's corvette (that's what I'm comparing to) but it would be a nice look and ponder for all of us truck guys.
So on your way to boost nirvana could you please make a quick stop at the lowly 8-9 psi and 2500rpm range? Thanks!
By the way, everything looks great! (as usual)
Russ
Russ
#23
FormerVendor
I am hoping to see some very nice results with regard to efficiency and IAT's. The 122HH that I had on it before did really good on this engine package. The engine is unchanged and we actually unhooked the NOS for testing. We will be using just boost and a little 100% meth for octane enhancement.
#24
FormerVendor
Russ
Russ
I would have to pull it all back off and convert to an underdrive unit on the rear to get down close to that boost level. With the largest pulley I can get on the front I should be around 14-16 psi.
#25
FormerVendor
Took it around the block last night. I will be tuning it this week on the supercharger pulley's I have for it now. I am still waiting on the new design supercharger pulley's to be finished later this week. I will try to get some video of it up this weekend. There are a few TBSS's showing up at my house on Sunday that will have cams with them.
