Tvs 1900 or 2300 for 427ci?
Old Jul 17, 2009 | 10:41 PM
BigCountryx's Avatar
2300.... It's about $1500 more expensive when talking front drive, front inlet setups. It would be well spent for a 427.
Old Jul 17, 2009 | 10:46 PM
zippy's Avatar
TVS2300. I wouldn't even question it.
Old Jul 18, 2009 | 07:59 AM
Denali08's Avatar
Originally Posted by supersub
My 2300 gets 12 psi with a 3.4 pulley up front on a 427.
What's CR of your 427ci engine?
Is it on pump gas for 12 psi?
Where did u buy your TVS 2300?
Can u PM me the price, if you don't mind?
Originally Posted by 2004SSS
you cant say a 2300 will make xx psi on a 427 , compression ratio plays a big part.
That's for xx rwhp at xx psi! But boost won't change with CR. It's affected only by pulley size and blower size. RWHP is the one affected by CR.
So, yes I am right about psi of the blower with certain pulley size.
Old Jul 18, 2009 | 08:04 AM
Denali08's Avatar
How is front drive and front inlet setup different between the 1900 and 2300?
This front drive and front inlet setup comes with the 2300 kit or it has to be sorted out?
Old Jul 18, 2009 | 08:09 AM
SuperchargedSS's Avatar
probably best to hit up leftcoast32 on here. he is a maggie dealer and pretty well informed on their products and specifics.
Old Jul 18, 2009 | 09:28 AM
leftcoast32's Avatar
FormerVendor
I agree, Compression Ratio plays a huge part! Positive Displacement Supercharger actually like a higher static compression ratio then other forced induction packages.
Old Jul 18, 2009 | 09:35 AM
FormerVendor
The TVS2300 can be ordered in 2 different configurations. The addition of the jack shaft on the front inlet/rear drive gives you the ability to overdrive the rear and spin the supercharger at a higher rpm.
Either of these will require the 8 rib front drive. The 6 rib just does not like to spin up that big of a supercharger. We also have the 8 rib systems dialed in really nice for these packages.
A TVS2300 Front Inlet/Front Drive on a 427 with 10 to 1 compression and 8 rib front drive system will do around 10+ psi. This is all dependent on the compression and cam selection. Please call with questions before the build starts.
Front Inlet/Rear Drive
Joe (760) 522-8669
Old Jul 18, 2009 | 09:37 AM
It's not much different except for compressor size.... In this example, the price difference should be in the $1500 range, which is what I tried to say....
Now, If you want to go with a custom rear driven / front inlet 2300 setup (like supersub) then the price jump from a standard front drive / front inlet 1900 setup would be quite a bit more.
Old Jul 18, 2009 | 09:51 AM
FormerVendor
They recently dropped the price difference from the Front Inlet/Front Drive TVS1900 to TVS2300 to $500.00 more.
So for $500.00 more you can get the Front Inlet/Front Drive TVS2300 but it doesnt come with a tune and will require the 60lb injectors should the boost be pushed up.
Old Jul 18, 2009 | 09:54 AM
FormerVendor
This is a Front Inlet/Front Drive
This is a Front Inlet/Rear Drive
