Turbo truck doesn't seem to be making good power...
#23
I always run at Empire.
I did another test today and installed a second boost gauge at the compressor cover. 1-2 psi drop across the intercooler at 15 psi boost. Not likely my problem.
I did however notice a slight miss over 5k today. I think at least. Ordered new MSD wires to replace my stockers and will put new plugs in and gap them a few thou smaller.
My only other idea is running through the converter, so I'll do some calcs on that as well.
If none of this makes a noticeable difference, I'm off to the dyno to see the curve and see what it's making.
I'll keep this updated!
#24
what plugs are you running? and what converter?
ive seen stock wires be a problem once you start making morepower so that could be a part of it, possibly blowing out spark too...
sounds like youre making progress though!!!
#25
I came up with a slip of 20.4%
I used this calc... Wallace Racing - Converter Slip Calculator
5200 RPM, 3.73 gears, 109 mph, 33" tires
Seems high, right?
Seems high, right?
#27
Missing isnt a result of blowing through the converter...if you were blowing through it the engine would just sit at a certain rpm and the wheel speed would come up slowly. I doubt the converter is your problem.
#30
Locked the converter up and did a short pull. Truck felt the same.
Hoping the wires and plugs make a difference. Otherwise, it's just slower than I thought it should be and will be upping the boost!
