Turbo questions....
Old Sep 10, 2008 | 08:08 PM
v8bug's Avatar
Default Turbo questions....
Turbocharger: Master Power T70
1. Is the exhaust housing clockable? I would like to move it 90* CCW (see pic)
2. If it is clockable is there anything I need to know to rotate it? torque on bolts?
3. Will 3/16 oil feed line be too large? I have lots of nice stainless swagelok fittings and found some 1/8" NPT - 3/16" hard line fittings. The stainless tube actual measures .175 ID. Planning on running -12 bung on pan for drain
Old Sep 10, 2008 | 08:11 PM
mike06tork's Avatar
yes just loosen the bolts and you can move it however you want.
Old Sep 10, 2008 | 08:42 PM
kbracing96's Avatar
Yep, like Mike said just loosen the bolts and rotate and tighten them. I've never used a torque wench on them cuz you can't get to all of the bolts with one on the turbine side I just tighten them till they "feel" tight . Both the compressor side and the turbine side can be clocked.
That oil line will be fine as long as you have some flex line in there some where too. I usually just use -4 push lock hose and fittings. It's easy and cheap.
kha4079
Oct 29, 2018 04:38 PM
lxcoupe
Sep 6, 2017 08:24 AM
jtphelps289
Sep 11, 2015 06:37 PM
slowswb
Sep 5, 2015 02:27 PM
06murder
Sep 4, 2015 03:54 PM
