? on turbo parts for Trailblazer
Old Feb 28, 2006 | 05:53 AM
icen's Avatar
Default ? on turbo parts for Trailblazer
This is the only place where i trust yalls judgement. Seeing how man people are makin so much power. Well im startin up my turbo project after finding a very good welder. I know my way around turbos, but just wanted to make sure from yall what tried and true parts i should use. Here are my goals on stock motor i wanna run 5lbs and then 7 to 8 with meth( i know i probly could go higher, but i wanna see how long the stock engine will last at this level). After the engine gets built i would like to run 800hp. I was either thinking either a gt-42 or either the new s70 or even a s72 for something to grow into when the hp bug bites.
1. What should i make the tubing out of and what diameter
2. Whats type and how big of a wastegate and how many if i get crazy with the boost.
3. What blow-off
4. should i use a t4 or t6 flange( i know thats dependant on the turbo)
5. What air-to-air intercooler would u use.
6. For an intake manifold wat is the best material to make it out of.
7. Also everything will be coated, but i have heard of mixed reviews between wat to actually coat it with. So wat would u use.
Thats all i can think of right now. Please add anything that u think i would need to just the turbo kit itself. I know i should start off with a smaller turbo and parts and go larger as i need, but money aint growin on trees and the engine will be built soon so i rather see wat i can do with this on a stock engine and only build the turbo kit once and be done with it. Thanks IceN
Old Feb 28, 2006 | 10:21 AM
duwem's Avatar
1) Stainless, whatever fits your components
2) up to you
3)Greddy seems to be popular
4) I think you answered that one
5) whatever will fit your application
6) stainless or aluminum if you can find someone to weld it
7) I would search to see what others have done
chopperloco
Jul 10, 2016 10:45 PM
Stainless Works
Apr 10, 2016 04:34 PM
EscaTruck
Jul 20, 2015 11:42 AM
maxspeed05V
Jul 19, 2015 07:08 PM
1320Chicken
Jul 14, 2015 10:58 PM
