Turbo oil feed on NNBS?
You will have to reduce that to at least a -4an or you will blow the seals out of your turbo in no time. I have no experience with the lingenfelter piece, but I did spend 2 days fighting an oil leak with another style of billet adapter before I threw the POS out and just tapped the feed block. It turned out much better. If I were you, I would put a tee in the cooler line just above the feed plate, and route a -4an line from the tee to your turbo. I think that would give you a simple worry free oil system.
Truck Sponsor
I was planning on tapping into the small plate that is above the oil filter for my oil feed to the turbo, but after getting under the truck and remembering I have the factory oil cooler, I noticed it has the big block for the oil cooler lines right there. Where did some of you get your feed from on the NNBS trucks that have the factory cooler? If anyone has some pics, they would help alot! Thanks for the help everybody.
My oil cooler is a stock piece but isn't stock on my truck. The plug was obviously already tapped and this is what I'm looking to use. The 90° hose end is for my turbo and is just used to see if it will fit. I'll probably end up trying out a tight, 90° coupler fitting with a straight AN hose end.
However, I haven't installed the lower bell housing cover to see if it will fit, and honestly, I don't think it will with the 90° hose end or the 90° coupler (pics of your setup Trick). If it doesn't work out I'm going to use the oil plug on the front driver's side and use that as my oil source. It won't be cooled or filtered oil but it's better than nothing.
Truck Sponsor
Yes that pulled. Drill it out, tap it and use a 90' fitting. think it was 1/8x-3 forged 90. Brass fitting gives the tightest turn. Not 90 hose.
Then a -3 straight hose.
I will try to find the pic. Been many moons back when we did it.
If the block is completely off. You can drill and tap the block. Just need to make sure it's cleaned out really good before reinstalling.
