turbo noob needs info (lq4+turbo)
Old Dec 17, 2013 | 12:28 AM
stroker87's Avatar
Default turbo noob needs info (lq4+turbo)
I bought a truck a few months ago that was turbo'd and got all the turbo stuff with the truck but it was on a different Lq4 that he blew up
2004 RCSB silverado with a 2001 LQ4/4L80e swap
have a few questions since I never played with a turbo before
how much boost can this engine and still be in a safe zone I probably will be doing a meth kit too and a FMI
the LQ4 is stock I was told I should swap to the LS6 springs?
do i need to stud the heads and/or change the head gaskets?
what size injectors should be used?
Old Dec 17, 2013 | 03:01 AM
LS1TRUCKGUY's Avatar
Depends on your goals. ARP head bolts or head studs with a set of LS9 head gaskets are always a good idea. I have ran 14lbs boost with a small cam and LS6 springs with no issues, but I plan on swapping to dual springs at some point.
Old Dec 17, 2013 | 08:45 AM
stroker87's Avatar
I'd like to get as much boost as I can and still be in a safe zone if there is one?
on stock gaskets and head bolts how much boost can it handle?
my goal is to have a daily driver that will run low to mid 12's drama free right now i'd say its ruining high 13's to low 14's
Old Dec 17, 2013 | 03:04 PM
thunderwagen's Avatar
I ran 11# on my LQ9 with stock gaskets and bolts daily for about 70k miles on pump gas no meth no issues. Only thing I had in the motor was a set of springs and pushrods.
Old Dec 17, 2013 | 07:56 PM
stroker87's Avatar
did you have to upgrade the fuel system?
Old Dec 21, 2013 | 10:01 AM
stroker87's Avatar
since the 17th and only 2 answers?
feeling really friendly in these parts.....NOT! what are we back in school i'm not one of the cool kids? LoL over 190 views whats up with that??
thunderwagen & LS1TRUCKGUY thanks at least you two had some input
Old Dec 21, 2013 | 11:31 AM
GRRR65GTO's Avatar
Yes you'll need a bigger fuel pump, my trucks not done yet but I put a walbro 400 in tank in my truck, they are only around $100.
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
gtyler04
Jul 28, 2015 06:21 PM
Cowboy Tom
Jul 21, 2015 10:29 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
