turbo noob needs info (lq4+turbo)
I bought a truck a few months ago that was turbo'd and got all the turbo stuff with the truck but it was on a different Lq4 that he blew up
2004 RCSB silverado with a 2001 LQ4/4L80e swap have a few questions since I never played with a turbo before how much boost can this engine and still be in a safe zone I probably will be doing a meth kit too and a FMI the LQ4 is stock I was told I should swap to the LS6 springs? do i need to stud the heads and/or change the head gaskets? what size injectors should be used? |
Depends on your goals. ARP head bolts or head studs with a set of LS9 head gaskets are always a good idea. I have ran 14lbs boost with a small cam and LS6 springs with no issues, but I plan on swapping to dual springs at some point.
Originally Posted by LS1TRUCKGUY
(Post 5172605)
on stock gaskets and head bolts how much boost can it handle? my goal is to have a daily driver that will run low to mid 12's drama free right now i'd say its ruining high 13's to low 14's |
I ran 11# on my LQ9 with stock gaskets and bolts daily for about 70k miles on pump gas no meth no issues. Only thing I had in the motor was a set of springs and pushrods.
did you have to upgrade the fuel system?
since the 17th and only 2 answers?
feeling really friendly in these parts.....NOT! what are we back in school i'm not one of the cool kids? LoL over 190 views whats up with that?? thunderwagen & LS1TRUCKGUY thanks at least you two had some input |
Yes you'll need a bigger fuel pump, my trucks not done yet but I put a walbro 400 in tank in my truck, they are only around $100.
